pecheckler
- Aug 17, 2012
I have a GTX 670 connected to a Vizio M551d-A2R via HDMI, and the optical output of the TV connected to a VIZIO S4251w-B4 5.1 Soundbar. I am unable to get 5.1 surround sound from the PC with this setup. I am conviced the problem is with the Windows audio or Nvidia audio configuration. Any help is appreciated.
When the PC is connected directly to the sound bar via an optical audio cable, the sound blaster recon 3d passes a dolbey digital 5.1 no problem. This television is capable of passing through both 5.1 DTS and Dolbey Digital 5.1 signals out of the optical connection. I have verified as much using a playstation 3 and received confirmation on that from Vizio support and from reading other costumer reviews mentioning the 5.1 audio passthrough capability. I was impressed that Vizio support was kind enough to troubleshoot with me for an hour and even offered to replace the TV before they would accuse my PC of being at fault.
Here is the playback device properties. Even though it shows dolbey encoded format, that doesn't happen. It also only lists 2 channel audio, which I think should be 5 or 7 channel on such a high end card.
And here is the nvidia audio settings (all I could find):
Thanks folks
Thanks folks
