CrashGawker
- May 30, 2002
Without a lot of background to explain things this might sound a little wierd but let's just take everything at face value unless there's something that really does need cleared up.
Basically here's what I have, my computer is hooked up to my internet connection via a Linksys WRT54GS, I also have a Belkin 802.11g wireless adapter that I use to hook into another network where I share files and printers and such. The problem is, in order for my computer to SEE the stuff on the secondary network I have to physically unhook my computer from my router because as long as I am hooked to MY router I can't access anything having to do with the OTHER router.
Is there such a way that I can set things up so that my computer only uses MY router for internet access and the other one for file/print sharing? Is there a way to set the computer up to use two different networks simultaneously? I've been unable to get those results on my own so I figured I'd ask here.
BTW I'm running WinXP but I'm not sure what other information you might need so ask away if that's not enough.
