hi, ive got a question about using SATA and IDE drives in the same system. Im planning on gettting the new MSI Neo4 SLI board and was wondering if its possible to use both SATA drives and IDE drives. the reason i ask, is that a friend of mine recently bought the board and installed a new SATA drive and an older IDE drive he had for storage( by older i mean from his old case). anyways, we formated both drives and installed windows on the first SATA drive (which was set as the priorty boot drive). everything worked fine up untill the point where he would reboot it. then he would get a boot error. and even taking the IDE drive out would fix it, so we would have to reformat and reinstall. finally, he just put the SATA drive in and left out the IDE drive. anyways, I also have 2 IDE drives that i plan on using in my new system, one internal and one that im gonna get a USB 2.0 external enclosure for, and im going to get a raptor 74gb drive as my primary drive. any ideas so i dont run into the same problem? thanks for any input you may have.
