Need Help Urgent!!!
Zidoas
I got everything from Newegg today. Put together the comp, turned it on and the screen tells me the:
Award Winning Bios.. blah blah
Main Processor: Sempron 2800+
and that's it... it just stops.
I've tried different rams and it still didn't work.
Any suggestion on what the problem might be? It just stops , i can't get into bios nor does it do anything after it tells me my Main Processor: Sempron 2800+
Please help!!!
Thank you in advance
edit: My mobo is an ECS 755-A2 V1.0
Ok this is pretty weird. Found out what the problem is.
When I plug in the PCI modem, it doesn't boot, but when I take it out, it works fine???
Also, any idea on why it isn't picking up my 1 Gig ram? It's only reading it as 512mb... and when I take one stick out, it reads as 256??? I am guess it is only reading one side of the 512mb stick???
It is not picking up my floppy drive neither!!! SOMEONE PLEASE HELP!!!
Thanks in advance.
Leave the PCI modem out for now and then reset the CMOS/BIOS by removing the battery and moving the jumper etc. etc. (with PC unplugged of course) and see if it will let you get into BIOS.
Thanks in advance.
The PCI modem issue sounds like a resource conflict. You might want to try another modem or try changing the PCI slot.
The RAM issue sounds like its related to density of the DDR. The chipset may not be picking up the other bank. That can happen when your chipset wants low density RAM but you have high-density.
IMHO ECS boards aren't always the best sorted out when they leave the factory. You should probably grab the latest BIOS upgrade and re-flash as soon as you get it up and running.
thanks for the responses guys. I've decided to just RMA the board and get myself a NF3 chipset based motherboard.
