Need help setting up new Samsung LCD
c00LaS1cE
I bought this 32" LCD (model no. LN32b360C5D) used in Korea and the guy I bought it from had it wall mounted so he hasn't been able to help me out. Here's the problem: in order to install the TV on the stand you have to remove the front panel. I cannot figure out for the life of me how to remove his panel. The instructions shown do not say how to remove this panel (my gf is Korean and read them). I'm hoping that someone on here has a similar Samsung TV and knows how to get this panel removed so I can install this TV that I've owned for a week now and haven't been able to use.
front panel
stand
rear panel
instructions 1
instructions 2
The two holes in your first picture, inside look like it could be push clips. Try depressing them with something and see if it pops out.
Someone on another forum thought of a really simple solution that I should have thought up a long time ago. Basically what I ended up doing was pushing in the tabs while lifting up on the panel with a flathead screwdriver. Samsung definitely could've made it a lot simpler by just having the tabs remove the panel instead of the addition of having to use the screwdriver though. Thanks!
