Fixing to start building my new house, I am doing all the wiring for phones/net/cable.
I am going to go with a Leviton enclosure, either 28" or 42". The deciding factor will depend on if I mount my switch inside the leviton or outside on a 19" rack bolted to the floor.
My questions:
1) I will have about 15-20 network connections. Should I bypass the leviton box & just use a 24port 19" patch panel? Then mount my switch in the 19" as well? If I do this, how do I best get 20+ NIC cables out of my wall and to the patch panel without it looking like shit?
2) Phone: I will have 1 line servicing 10-12 jacks. I want to be able to down the road add a 2nd line possibly. What leviton item would best do this for the least amount of $? I am weak on phone stuff knowledge so help here is needed!
3) Cable: is 1x8 the most spliting I can do? And is 1ghz or 2ghz powered splitter really needed with RG-6? I wont be sending cable modem signals out thru it, only cable TV or sattelite. Cable modem will be with the switch etc on a seperate cable (2 cables from outside to my wire closet, along with 3 cat5e's for 2 phones and possible DSL if I go that route)
4) I plan on runing outside speaker wire (back porch) and living room and kitchen back to the leviton. Sound to these would be controlled by my PC near the closet. What module is best for 3 pairs of speakers? And what do I need to run from the leviton to the PC to get sound to the speaker wires?
Any other additional tips would be appreciated. This will be my first (and last!) house to wire like this!
PS - Wall jacks and keystones are a breeze....just need help on deciding the Leviton modules that would best suit my needs.
My questions:
