Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Just received an essence one for Xmas. It has a voltage switch on the back of 115v or 230v. I live in San Diego and I think my plugs are 110v by my pc. I don't want to blow the DAC. Can you help?? I tried to google but want expert advice. Thanks
I've reinstalled windows 7 64bit and installed asus drivers. All works fine. My questions are: which sample rates are supported? The only one selected in properties is 48 kHz. Also under advanced is default format which has 2 channel 16bit 44100hz (cd quality). What should be default? I have up to 192000 24bit? I'm about to download foobar2k and I'm a newbie there too. So more questions on the way. Thanks
