need help picking a res
EricFX1984
I need to pick a res, my case is a NZXT Gamma with a NZXT M59 side window
would really like to keep it under $55 shipped
here is my current setup
I am adding a water cooled Palit gtx460 1gb on friday
I will also likely be moving the d5 pump, and maybe even upgrading to a MCP-350 (modded to MCP355)
With the tubing going out the back just above the fan the space around the rear fan is likely to be very crowded. a 5.25 base res might be better.
Is your pump flowing to your CPU block first?
Mean looking loop!. :cool:
I don't know enough about water cooling hardware to help out.
Just checking your system out.
