need help on the FINAL decision...
jack9800XT
Ok I think I have pretty much made up my mind on either one of these systems but cannot decide which one. Please give me your opinion on what system you think I should go with and please point out any problems that you see or suggestions.
1-
- AMD Athlon64 3000+
- ASUS K8V DELUXE K8T800 S754 MOTHERBOARD
- 1 gig bargain bin DDR400 pc3200
- LG 52X IDE CD-ROM OEM
- WESTERN DIGITAL 80GB 7200RPM SATA HARD DRIVE
- Antec Sonata (with inc 350 PSU)
- First x800pro or 6800GT I can get my hands on
- cheapest display I can get for now
OR -
2-
- AMD AthlonXP 3200+
- ASUS A7N8X-E DELUXE MOTHERBOARD
- OCZ DDR 400 1GB PC3200 DUAL CHANNEL KIT
- PIONEER SLOT LOAD 16X DVD ROM DVD-120S
- Antec Super Lanboy
- Antec Truepower 430 PSU
- First x800pro or 6800GT I can get my hands on (maybe U or XT PE)
- A good display (have not decided, imput?)
mmk, both are descent choices, here is what id do:
(Kinda looks like my system, but with a better video card :p )
- AMD AthlonXP 2800+ - $120
- Abit NF7-s - $85
- Kingston Value 2700 Dual Channel 1Gig - $170
- Some sort of CDRW/DVD Combo - $40
-Creative Labs Sounds blaster 2ZS - $70
- First x800xtpe or 6800U you can find
- A good display
A good monitor is important, what kind are you looking for, CRT or LCD?
I would recommend a CRT, 19", looks better and is cheaper than a LCD!
As far as the processor goes, i would say get the AMD64. And thus you would be getting the ASUS A8V motherboard.
How much were you planning on spending?
