Need HELP on overclock very quick please.
murilo305
I am planning on overclocking my pc It is
Processor:Intel® Core™2 Duo Processor E6600
Motherboard:Quad-Core Supports) Asus P5N32-E nForce 680i SLI Chipset LGA775 FSB1333 DDR2 Mainboard
Powersuply:500 watt.
For the porcessor would it be better to overclock a AMD Athlon™64 X2 6000+ Dual-Core CPU w/ HyperTransport Technology or the Intel® Core™2 Duo Processor E6600.
I heard its like a chance to overclock I really dont no but i would appriciate your help.
Don't start overclocking until you understand the socket types of processors. :)
Be careful, and best of luck.
the e6600 clocks way better than the amd. the amd is almost at its limis stock....
i have an asus board, the plain p5b-plus, and the e6600, i have had it orthos stable at 3.8 ghz with 1.575 core volts.....
now i dont suggest you try this at first, read up on it, and understand what you are doing.
and remember, Ocing is dependant on more than just a cpu, you need good ram, psu, mb also.:cool:
read up on it first, then come back, id be glad to help you get a good oc. if you air cooling, dont get your hopes too high, say 3- 3.4 ghz.
You are using watercooling then I assume?
1.575 volts is getting very close to the edge with that CPU. I do not recommend going over 1.5 unless you have good cooling and money(plus CPUs) to burn.
