NEed help on OC
zbgsaa
OK system specs
AMD 2500+ running at 182x11 stock hsf
Abit NF7-M, using onboard audio and video
1x512mb Buffalo 3700 466 @ 364mhz 2 2 2 6
Ok i tried running my ram at 2 2 2 5 but it will get into windows and crash running at 2 2 2 6 it will run but there will be little white flashes on the screen...i upped voltage to 2.7 on it
What is causing these flashes and what should i be able to run my memory at stable?
Look at the chips on the memory. On the chips, you'll see a few numbers/letters --> post them here.
You probably have the PC3700 w/ Micron rev C chips, as the Buffalo PC3700 w/ Winbond BH-5 disappeared a while ago.
If you do have these micron chips...then you can stop hoping for those timings..cuz you aren't gonna get it --no matter how much voltage you push through it.
