Need help, New build won't post......
mitcity22
Ok I put together the rig in my signature, when I turn it on all fans come on, HD even spins, there is one beep (which is normal for my mobo) but nothing else happens, the fans just keep spinning.
The only thing I see that is wrong is that the two LED's on the mobo do not light up and in the user manual it says that this means " Abnormal: CPU or Chipset error"
I have cleared CMOS, tried both sticks of RAM in multiple slots. What do you suggest I do? :confused:
Unless I saw it my self I dunno really what to tell you, would you mind taking a pic inside the case (just straight on) so I can look at the internals? A mistake I make a lot is forgetting to plug in those extra power connectors (such as the 4/8 pin power connectors on motherboards) so just make sure you got all that plugged up, if thats not it, it could be a DOA CPU or motherboard.
