I am a linux n00b, I'll admit that right away so you know where I'm coming from, I don't buy into the open source community as much as some people here but to be fair I'd like to give it a shot wherever I think it fits.
I have few users at work that need to setup home LAN's with web-filtering, mainly due to kids... since $$$ is always an issue in home environments I figured I'd give open source a shot
I believe my best shot at this is with IPCop & DansGuardian , is that correct? Are there any just as good other options by the way?
In any case... I have IPCop 1.4.10 running fine , only the protected & external interface setup on it. (green & red?)
now I'm trying to add DansGuardian and having one hell of a time
1) I noticed that DansGuardian does not like the latest IPCop version, but I am trying to follow this website here which claims that it should work
http://hiro-tan.org/~ekoontz/ipcop_and_dg.html
2) I have both the dansguardian and dansguardianGUI tars copied on there in \tmp
3) I used tar xfz name.tar.gz to extract both and I have put them into \tmp\setup
I did not use the ssh or scp commands, I used WinSCP to copy files over and then its terminal window to do the simple tar xfz....
now what do I do?
now what do I do?
