I have two Socket A heatsinks that I need to identify. I posted one in the past, but the currently disabled search functions make it difficult to find the response. Pictures are below:
The first is ThermalRight's AX-7, still have one running a Tualeron 1100 @ 1500 The second looks a bit small to be the 900A, I would say it's one of the SLK-800 versions, of which I have cooling an Athlon XP, and is basically the 900 but built for 80mm fans (and obviously smaller).
Thank you for the ID on #1 - that's correct (memory is returning on that one).
I now think #2 is either the SLK-900 or SLK-900A rather than the SLK-800 since mine has a pair of grooves running across the top-middle. I see this in pictures of the 900, but the 800 appears to have a flat top until the edges rise for the different fan sizes.
