Need help getting raid setup/configured
WorkingSux
I'm a 100% "newbie" when it comes to raid. I have 2 brand new seagate 200gb drives. One is sata and the other is ide. What I need to do is to get them formatted/partitioned and get them hooked into a raid-1 (mirrioring) configuration with the sata as the main drive and the ide as the backup. Currently I have 2 western digital ide hard drives, a 80gb and a 60gb, which I'll be needing to get transferred over to the sata drive as they contain my os and other files. I don't have a clue as to which steps to do in which order while not loosing the info on my wd drives. Those drives will be pulled out after all this is finished so they will not be in use after all this is done but will need to be formatted before removal.
My motherboard is the asus p4p800-e deluxe. Whats the quickest way to get me setup? As far as partitioning goes, I was thinking 50gb as the primary partition, then the rest in 25gb extended partitions.
Thanks in advance!
Scott
No one knows??????? I spent the last 5 hrs trying to get the raid working and I can't. I just don't know the steps to do it. So at this point I doubt I'll bother with raid because its nothing but a waste of time. Heck I dunno if I can even use a ide AND a sata together for raid1.
