I just got the koolance exos al, but the CPU water block does not fit, the plastic support where you clip on the water block is 90 degrees different.
The water block wants to clip on the horizontal way but the motherboard mount is vertical, I have the ASUS KV8 Deluxe.
Can some one reccomend me a waterblock that can fit my motherboard??????
