soulsaver_8229
- Mar 17, 2005
trying to type fast to beat a blue screen, something to do with ati.....
anyway i messaged my gf on yahoo, sent her my cam link, said it couldnt find cam (all other usb devices seem to be working fine) and then i restarted thinking maybe jsut need a refresh
i restarted and windows just loads up my background, nothing else (im able to get online by ctrl, alt, delete start a new task) nothing else is showing but my background, any help with this will be so very nice
i rebuild boot ini file with windows disk, i did chkdsk, ummm only bios settings i changed are, the cashe shadow 32k think......set that to disabled, and APIC function disable.....if theres anything yall can help me with thatd be great......
i want to format trust me, but i dont have an external hard drive to save all my music, pictures, movies with and i cant burn anything to cd cause well i cant get it to work since nothing is working with out starting new task
my specs are
amd xp 2000+
1 gig of geil ram
9600 pro
windows xp sp2
thanks for any help
soulsaver_8229
my specs are
amd xp 2000+
1 gig of geil ram
9600 pro
windows xp sp2
thanks for any help
soulsaver_8229
