Chris_B
- May 29, 2001
At present my quad core q6600 at 3ghz (stock volts) is hitting around 80c on quad prime acording to coretemp and intel TAT. The cooler im using is a noctua which at the time i was told was a good cooler, doesn't seem to be able to take the heat of the quads though.
Would a tuniq tower make much difference to the temps? Been looking at some reviews and it seems to be second only to the thermalright 120 by a few degrees. Anyone here usin a tuniq on a quad core?
