Need help, computer wont turn on.
Private_Ops
Hi everyone,
My mom brought in a computer from work for me to look at, its not a name brand and appears to be custom built. It has a P4 and 256mb of RAM. The motherboard is an ASUS P4P800-MX. The powersupply is a 270W FSP of an unknown formfactor (and damn is it small).
The problem is that it wont even remotely turn on. I popped the cover off and had a look inside and everything appears fine but, i did notice when the power is plugged in and you flip the PSU on (has a main switch in the back for cutting off power to the whole system) the PSU puts out a very faint high pitched squeal. This tells me something is wrong with the PSU but i could be wrong. Taking note that it appears to be custom build nothing should be proprietary so I'm gonna try a different PSU and see what happens. I'll post back on the results but in the mean time I'm looking for suggestions on what could be wrong from my fellow [H].
DISREGARD I found out the PSU is blown, but I'm gonna go on ahead and thank anyone that would have helped me
Are you sure its not a micro ATX form factor, or SFX? Most 270W FSP models are, and I actually have one that died on me recently. I replaced it with a TOPOWER unit, but there are some brand new Seasonic units that should be out by now. Go with a higher quality FSP if you don't want a Seasonic.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817104021
Its that, Quite interesting on how small it is, let alone running a P4 (luckily tis a Northwood).
My moms gonna order a new one for it.
Yah, thats a MicroATX PSU. I had one powering my P4C 2.4Ghz and 9800Pro for a couple of years.
Actually, a Core2Duo uses less power than a northwood, lol. Anyhow, as I said, replace it with a good quality one, or it'll suffer the same fate in another couple years.
