Need help buying psu
Patman
What power supply do I need for this sytem. I wasn't sure if I needed dual rails or not. Any help is appreciated. Thanks.
AMD Athlon XP-M OC to 2300mhz
2 Maxtor ATA133 7200rpm drives
2 Raptors 74gig
6800gt by evga
1 optical dvd burner
2 sticks of ram
4 case fans
I currently have a 400w powering everything except the 6800gt. I want to add it. I also want to be able to add a wc pump later on and have room to overclock my video card. Thanks again!
48db? are you joking me? I like my hearing, thanks, anybody else?
If you want quiet you want a Seasonic. Yuo could use either a SuperSilencer or SuperTornado(misnomer) in your system. The S12 series will also work but you don't need the dual 12v. Take a look at the reviews at www.silentpcreview.com for how quiet these supplies are.
http://www.newegg.com/Product/Product.asp?Item=N82E16817151015
http://www.newegg.com/Product/Product.asp?Item=N82E16817151022
http://www.newegg.com/Product/Product.asp?Item=N82E16817151007
http://www.directron.com/ss350fb.html
