Very little gaming, Adobe Creative Suite (Illustrator, Photoshop, Dreamweaver), Web Browsing, Watch Movies.
I do not have a set budget, I am flexible on this.
3) Where do you live?
California
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything
I will not be reusing any parts from my existing computer.
6) Will you be overclocking?
No
Dell UltraSharp U2410 24 inch Widescreen Monitor
Preferably within the next 1-2 months
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Not sure, I don't plan on utilizing Crossfire or SLI because I don't think anything I do is that graphics intensive, but if a motherboard has the ability it won't hurt.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
I have XP Pro, however, with a new build, I figure Windows 7 would probably be the way I would go.
Some things I am interested in and would like feedback:
I was thinking the primary drive would be SSD, and I would like to have as many terabyte drives as I can as backups, I do not want a noisy computer as this is in my bedroom
so the quieter the better. Fancy cases are not a necessity, I want something that will last me a while as I do not upgrade often. I only have 2gb of RAM right now and I
have issues with Adobe programs especially, so I would like to resolve that with more RAM, open to input on this as well.
I do not have much knowledge on hardware so any advice is greatly appreciated. Thank you.
California
Everything
No
