Hi,
Im planning to get either of these setups currently
1) 2xSeagate 7200.12 1TB for Matrix RAID(0,1)
2) 3xSeagate 7200.12 500GB for Matrix RAID(0,1)
3) 2xSeagate 7200.12 500GB for RAID5
All three setups cost about the same. If I choose 1, I will get most $/GB value. Im not sure 3 7200.12 will be much faster than 2 pcs in RAID0 for daily applications, OS and games loading. If I choose 3, Im not sure RAID5 is fast enough or at least match 2pcs of hard disk in RAID0. Storage size is not a matter for me because I have another 1TB Samsung F2 for storage.
Im also considering to get SSDs in RAID but with my tight budget, Im aiming for cheap ones like Patriot Warp v2 64GB and plan to get a pair for RAID0. A single SSD will cost a much of the setups above though. Warp 32GB is out of stock and 64GB is cheaper per GB. Would a single high end SSD like Intel X25-M beat out two Patriot Warp v2 64BG in RAID0? X25-M rev 2 is currently out of stock though. Or should I wait for SSDs to mature and get cheaper and just go for mechanical drives? Thank you in advance.
__________________
__________________
