I REALLY need help choosing a video card for a new HTPC build that my wife is INSISTING I do quickly (really!).
THIS WILL BE A DEDICATED HTPC feeding a 52" 1080P LCD TV not a gaming rig.
So Im looking at the ATI HD 2600XT family with DDR4 or DDR3, ether 512M or 256M.
A CrossFire setup is possible, as is the real-soon-now Gemini cards (those with two 2600 GPUs on one card).
So . What helps HTPC 1080P playback (and keeps the load off the CPU) most?
(Please dont guess if you dont know)
1) 512M vs. 256M?
2) GDDR4 vs. GDDR3?
3) Faster vs. Slower GPU speed?
4) CrossFire vs. Single card (to allow 256 bit memory bandwidth vs. the 128 bit native)?
Please remember, this is not a gaming rig and Im willing to pay for a card that gives more elbow room to overall operation.
Cooling and noise should not be a problem, as Ill be using an Antec P182 case.
Thanks for the help!
PS: New HTPC (building)
Intel Q6600 on DFI LP UT P35-T2R (or similar Asus)
2G of DDR2 with fast timings
Two 500Gb SATA HD (not RAID)
DVD-RW SATA Drive
Antec P182 cast (with 120mm fans in all mounts)
Corsair HX650 PSU
Vista Home Premium MCE
1) 512M vs. 256M?
2) GDDR4 vs. GDDR3?
DVD-RW SATA Drive
Corsair HX650 PSU
