need cpu fan suggestions.
geekcomputing
I need a better cpu fan, something that is quiet.
my current fan is a stock amd fan and its a screamer.
I do not plan on overclocking at all. The priority is something that will be quiet yet keep my cpu from frying.
cost is not a concern.
Thanks!
If cost does not matter then get a whole new heatsink, a good fan on the stock cooler will be all but a waste, you can pick up good coolers that will be VERY quiet on a stock chip. What socket/chip do you have?
sorry for the confusion, yes, i will need an fan/heatsink combo.
i have an AM3 socket (amd quad core 3.2 giz black cpu)
the mother board i have is an aus m4a796 deluxe if that helps at all.
Scythe has many good options for a low price and are quiet. I have used many different models and they are all low noise.
