Need CPU cooler.
Proxy
Pumpkin Ghost
So basically I am getting ready to change to a new case (one that can be setup for better air flow) due to heat issues. So I want to get the best CPU cooler I can to go with that, but one without a huge footprint (I don't want it to bump into my RAM slots on my motherboard). For a while I was thinking about the Corsair WC, but then I realized that would be an insult to WC'ing. I mess around with my box to much to want to worry about an actual WC setup, so I'll stick with good air for now.
Here is a picture of my case:
My bottom video card gets way to hot after extended hours of play due to the heat from the PSU. Getting a case with the PSU mount at the bottom was a bad idea (case looked really cool though, no pun).
Id highly reccomend the TRUE, have one on a p6t dlx v2 and it fits fine.
As you can see in my pic my ocz reaper fits great (had it in first slot by mistake lol) but at least i know that 12gb will be fine. Chip clocked at 3.8ghz, load temps at 70-65-67-64.
Awesome, thanks! That was the cooler I was going to get, but figured it might be too big.
Well...you might save a few bucks and gain a few degrees. If you have the money to spend go buy a TRUE.
I have a lapped TRUE. If you are interested send me a pm. going on water so i dont need it anymore. thanks
If you want to sell please do it through a for sale listing. If you can't do that I suggest you try other means.
