I have an aspire x-dream case
http://www.newegg.com/Product/Product.asp?Item=N82E16811144001
possible:
2 80mm front intake, one 80mm hole at top, one on side, two 80mm exhaust
im running 3 panaflo 80mm L1A's (the 21db ones)
one intake, one blowhole up top, and one on my heatsink
my heatsink is a thermaltake .. dont remember exactly but i think its an slk 900, pretty old, but the point is, it doesnt come with a fan, and the biggest fan you can put on it is a 92mm. Im running an 80mm panaflo on it right now.
http://www.silentpcreview.com/article72-page1.html
I can turn on my two 80mm stock fans that came with my case for one exhaust and the side fan, but they are pretty loud and only lower case temps by 1 or 2 degrees C. Is there any use in buying a 120mm fan + a 120-->80mm fan adapter? Anywhere I could put it to get better airflow or better temps? a 120mm fan might be able to fit in the front intake of my case... but I'm not sure how much it'd help.
possible:
