I have my water cooling all set and my OC maxed out. The only problem is when I OC'ed I had my case open so my temps are with the side case open. When I put my side panel on things really heated up. I almost know it's because I have more air coming in then going out and the hot air is drowning my system.
Since I dont have a camera I drew up a picture for you visual learners.
The only air coming in is from the 2 80mm fans (F4) that came with my Lian-li PC6070B. I'm not sure how much air these two take in but I know it's more then my 80mm fan (F1) sucking 15cfm. I think I'll have to replace fan labeled F1 with something stronger and/or add another fan below it.
Any ideas or fan recommendations?
