As the title says, i'd like some advice on what HDDs to use for a storage server that I will make out of some spare parts when i upgrade my pc in the coming weeks. I've been out of the HDD market for awhile, the largest thing I have is a 250GB drive
I'd like a 3-drive raid 5 array which should be enough for now. I've been looking around and have seen that there seems to be a lot of problems with seagate barracudas, so i'd like to steer clear from those. From what i've seen so far, I'm liking some of the Samsung Spinpoint series drives and some of the WD Caviar Green and Black series drives. I'm looking for drives that are at least 1TB, but preferably 1.5TB.
Drives that have caught my eye so far
Western Digital Caviar Green WD15EARS 1.5TB 64MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136513
Western Digital AV-GP WD15EVDS 1.5TB 32MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136495
SAMSUNG EcoGreen F2 HD154UI 1.5TB 32MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152175
Western Digital Caviar Green WD10EARS 1TB 5400 RPM 64MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136490
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
Like I said before, the main purpose of these drives is going to be file storage, backup, and maybe some video streaming. Out of the listed drives, what do you guys recommend? The 1.5TB WD Caviar Green drives can be had for $100 including FS, while the 1TB WD Caviar Black drives can be had for the same amount. What do you guys recommend, more storage or better performance? And how good/bad is the performance of these WD Green drives? I'm leaning more on the side of more storage, but i'm open to suggestions. Thanks for any and all help
