Need advice on building a comp
Piph05
This is going to be my first time ever building a comp, so i am going to need some suggestion on what products to buy. I would like to try to keep the price under $1000. I plan on using this rig for gaming, higher end graphic games like Oblivion etc. I am not a hardcore enough gamer where i would want every setting maxxed, i just am looking for a system that will be able to run the newer games on decent settings for the next couple of years.
I already have the monitor, speakers, sound card, keyboard and mouse. I also have a case from the 8200 dell dimnesion series if i could use that.
For the video card i was looking at the Radeon x1800xt 256/512mb or the Geforce9700s. I was hoping to probably get around 2GB of ram if it can stay in my price and probably about a 100-200gb harddrive. Now im really not sure what type of motherboard i should get, but for processor i was thinking along the lines of an Athlon. Basically i really have no clue what i could get for or under $1000. Any help would be great. Thanks.
I would go
X2 3800 (dual core)
x1900xt they seem to be the better choice over the 7900s
an a8n sli newegg has them on sale for about 100$ (weekend only)
2gb of memory, whatever you like and is within your budget
http://www.newegg.com/Product/Product.asp?Item=N82E16819103562 297$
http://www.newegg.com/Product/Product.asp?Item=N82E16814102003 389$
http://www.newegg.com/Product/Product.asp?Item=N82E16813131524 105$
http://www.newegg.com/Product/Product.asp?Item=N82E16820231047 160$
total 951$ plus shipping and tax if it applies
rcf1987 said:
I would go
X2 3800 (dual core)
why not get like dual 7600 gts
little over the 1900`s price but beats it in budget and performance no?
Because he has the money, then he can do crossfire later
Piph05 said:
thats an am2 mobo your processor won't work with it look for an AM2 cpu
Two 7600GTs don't even beat a single X1800XT in Oblivion.
Piph05 said:
When i went through new egg i came up with something like this:
COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel, SECC Chassis ATX Mid Tower Computer Case - Retail - 44.99
Seagate Barracuda 7200.9 ST3200827AS 200GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM - 84.99
I do not really think i would buy this rig away though since from what i read AMD and Intel are coming out with new stuff soon and prices will drop alot. Any opinions?
I'm not too fond of the Centurion 5 since it's only got an 80mm fan in the front, and it isn't even free-flowing. See if you like the Antec SLK3000B.
The Samsung SP2504C is cheaper, quieter, and larger than the Seagate.
If you can wait, you should. Price drops and new stuff are coming.
IMO its not a bad idea to get as SLI motherboard now since the prices aren't that much diffrent. Also you might as well get a monster powersupply now if your serious about going dual card. Two high end cards suck a ton of power.
