Need advice on a cheap case.
BravO)))
I have been looking for a cheap atx case with good cable management and have been over runned with a lot of names I don't know and trust yet. Any suggestions would be appreciated. I don't care what the name brand it is as long as it is a good case.
If you list the system we could know what you have and the accomplished goals.
I am looking at spending up to 75 bucks. I will be running a 790fx with either my 4870 or 4870x2. I also have about 4 to 6 hdd's I will be using. I will also be using a tr2 500 watt psu.
What are some cheap ones that I can run the cables under the motherboard?
Second the RC-690, terrific case.
Just don't use the built-in cable holders, they unscrew, remove them. :p
