Ok...
I'm looking to build three systems
The first one I was thinking for my main system:
2x -AMD Athlon 64 FX-74 Windsor 3.0GHz 2 x 1MB L2 Cache Socket F (1207 FX)
ASUS L1N64-SLI WS Dual Socket L (Socket 1207FX) NVIDIA nForce 680a SLI
2x -EVGA 640-P2-N821-AR GeForce 8800GTS 640MB
BFG Tech BFGRPHYSX128P PhysX Processing Unit
-Doing light gaming, nothing major, but I want fast, multi-processing power
Am open to Intel Quad core system, but for that I was thinking dual quad core.. but I do want SLI or Crossfire for it
Then I want two mid-level systems, one based on Intel and the other based on AMD, one is crossfire the other is SLI
Crossfire Enabled System (mid level)
AMD Based CPU
ATI video cards 2x 2600s
Motherboard
DDR2 based ram
SLI enabled System (mid level)
Intel based CPU (C2d) (have 6420 that I can use)
Motherboard must support DDR3 ram
Nvidia video cards (2x8600)
Phys-x card
Ideas, recommendations, Advice?
AMD Based CPU
Motherboard
DDR2 based ram
Phys-x card
