[H]eckel
- Apr 8, 2001
I'm not exactly sure where I should post this thread, but since everything goes through the motherboard, I guess I'll start here.
I just built a new computer and when I got the os installed it was extremely unstable.
This is the main system components and configuration..
Asus P5N32-SLI Deluxe
Pentium D 930 3.0 Ghz
Leadtek 7800GT x 2 in SLI configuration
WD Raptor 10k RPM 36GB x 2 configured in RAID 0
OCZ memory 1GB x 2 dual channel DDR2 667
Here is the problem in more detail. Halfway through the first attempt at installing the os(xp pro) it bluescreened.
I started over and got the os to install the second time. There were a few read errors during the second installation, but I assumed there may have been some scratches on the cd. Retry worked the first time on each error.
The problems really started to be noticable when I got in to windows after installing the motherboard drivers(sound, lan, chipset). When I went to download the newest video card drivers, ie crashed a few times. I finally got it downloaded and when the install files for the video card drivers were extracting, it said the file was corrupt. I tried it again and it started to work the second time. Halfway through the video driver install it bluescreened again.
I tried this several times and finally got the video drivers installed, but then ie froze during windowsupdate every time I tried it and made the computer unusable.
I did install the asus motherboard monitoring software and all of the temps were low(18 degrees celcius on the cpu) and all the fans were spinning fine.
I have a couple questions at this point.
When I set up the stripped array it asked me for block size saying that the larger the block, the better the performance. I set it up at 128kb which was the largest option. There was also an "optimal" option. What does the "optimal" option set it at and could this have anything to do with my problem?
What about memory timings and stuff like that? I am running everything default and auto in the bios settings. It almost acts like a computer that has just been overclocked too much.
Any ideas here would be much appreciated. I think I'm going to redo the raid setup and try that. If that doesn't work, I'll see if it works without RAID and narrow it down from there, but if anyone could offer some advice to speed up this process it would be very helpful.
Thanks in advance for the help.
