Need a shroud
1quicksi
Running a Swiftech RadBox and wanted to get a bit more performance out of the colling system. Any recommendations for a shroud that will fit this setup?
make one out of card board/Gator board and duct tape first to see if it does anything for your temps...then you might want to look at plastic or aluminum
^what mike said, heres mine:
Yeah, I wasnt going for looks at all, but it works. Another things you could use is tubberware, if you can find a piece that fits. For making a metal shroud, this is a pretty good guide: http://www.ocforums.com/showthread.php?t=308900
Just make your own. Here's one I made with cardboard and duct tape. Took me about an hour and a half.
My company makes the mini-CoolShroud the large modding online retailers carry it.
For the whopping $10 even if it was a minimal improvement it would be worth it.
Thank you for the link, will go grap one :)
