need a cable/adapter..help please
Trikzy
I need a cable or adapter to convert a 4 pin molex to a 3 pin female fan plug, so i can plug my side fan into my motherboard, when i try and monitor fan speeds and such, with it not being plugged into the motherboard it doesn't show up on the list.
if you plug a 4 pin fan into a 3 pin connector so you can plug it into your motherboard, you aren't going to be able to monitor the fan speed anyway. there isn't a RPM pin on 4 pin molex cables.
Thanks, didn't know if it would be possible or not, didn't really think it would.
jaqie said:
and you can't google yourself?
or maybe make one yourself?
The reason i asked here is, because i could never find one, i always found the one you linked to.
