extrafuzzyllama
- Jul 29, 2010
hi all my first time posting and am kinda new to home networking.
i have been using a linksys wrt54gl and a linksys workgroup 5 port switch but decided i should upgrade
i was looking into buying a netgear rangemax wndr3700 dual band wireless n gigabit router and maybe a procurve switch but not sure which model i have no idea if i should get a managed or unmanaged switch
i am pretty set on a procurve just not sure which exactly
i am trying to use gigabit to handle hd video streaming over to my wdtv live from my pc
i will scrap the wdtv live once the boxee box comes out and build myself a nas once i get all the hardware needed ready
i will be connecting my imac, pc, nas, xbox 360, ps3, and for now the wdtv live and soon the logitech revue and boxee box to the switch
well to get to the point i would like to know what my best option would be for a procurve switch and a gigabit router and if that netgear router i listed earlier is any good
i am trying to stay around $150 for a router and under $100 for a switch
also should i replace my cat5e cables with cat6 since i am upgrading my router and switch to gigbit?
i just listed all the things i plan on doing in my network so that someone can recommend if a unmanaged or managed switch would be better and router suggestions as well
thx for reading guys
