Unfortunately I live in Greece and I just have only those two options
if I want to get a Nec/Mitshu 22 incher.
Nec FE 2111 SB 22''
MITSH Diamond Pro 2070SB
Mitsh 2070 SB goes almost the double price as the the FE 2111 SB 22'
I am going to work mainly on 1280x1024 resolution so the higher options 2070 SB gives is goin to be more likely wasted
I really want to know if I am goin to see any better graphics quality on 2070 SB that worth to spend almost the double amount of money for it?
In addition i know that there is another Nec model the FP 2141 that is identical to 2070SB and cheaper but unfortunately it doesnt exist in Greek market.
There is another option at the same price range with the FE2111 SB the Viewsonic P220f .
So , please give me your advice
Go for one of the FE 2111 SB or Viewsonic P220f and which one you suggest?
Or totally empty my pocket and get the Mitch 2070SB ..
Thanks in advance looking forward for your replays since that matter bugging me for the last 2 months now and drives me sorta crazy eheheh
cheers .....
P.S. BTW if anyone need somewere to stay for the 2004 Olympics in Athens you are more then wellcome to stay at my place ......hehe
"The only thing i know is That i know nothing "
Socrates
Nec FE 2111 SB 22''
cheers .....
Socrates
