nathan2525
- Dec 13, 2014
Hello everyone! Long time forum reader, first time poster. Ive been planning on building my first PC for a long time, and finally managed to get my hands on an NCASE M1. I would very much appreciate if anyone could look at my intended build to make sure I havent made any terrible mistakes!
Build:
Case: NCASE M1
CPU: Intel Core i7 4790K
Motherboard: ASUS MAXIMUS VII IMPACT
PSU: SilverStone 600W SFX Power Supply
SSD: Samsung 500GB SSD, 840 EVO Series
GPU: GIGABYTE GeForce GTX980 G1 Gaming
Cooling: Noctua NH-C14 CPU Cooler
RAM: 2 x Corsair 8GB 1600mhz DDR3
Monitor: Undecided
Sticky Post Questions:
1. Uses: Predominantly gaming Witcher, Dragon Age, TF2, DotA/LoL. Would also like to use as a Plex server for my house but gaming is the main priority.
2. Overclocking? No. Watercooling? No.
3. Budget: Anything between $1500-$3000. Would always be happy to spend less rather than more, but happy to splurge if Id get significant improvements.
4. Where do you live: I live in Australia. Will be using Scorptec/MSI most likely.
5. What exact parts do I need? Ive already purchased the NCASE M1 and GIGABYTE GeForce GTX980.
6. Reused parts: None
7. Specific features needed: ability to play games, would like be able to use two monitors as well however I dont know if thats achievable.
8. Resolution: no specific preference. 1920x1080?
9. Space and optical drive: It doesnt need to fit into a particular space, but Ive purchased the NCASE because I wanted it to be small! I dont need an inbuilt optical drive.
10. Case modification: preferably not. Too intimidating! I have a set of small screwdrivers my little brother used to build his PC
11. Noise: Would always prefer quieter however not a major selling point.
12. Mobility: would appreciate mobility, but again not a huge concern.
13. OS License: I posess Windows 8.1 Full version with 32 and 64 bit DVDs
14. When do you plan on building/buying: As soon as possible! Hoping to get it built/bought by the beginning of next year!
My main questions are:
1. I too late realised that the GPU I purchased wasnt a rear exhaust type card. Will this be a major issue? Its still new in box and I would potentially be able to resell it online and buy a reference style card however would prefer to avoid the inconvenience if its not going to be a major issue.
2. I dont fully understand how to install fans/how many I require. Ive chosen the NH-C14 because Ive seen other people use it for the NCASE will I need to buy additional fans as well? Or will that be enough?
3. Any general tips for PC building/building in the NCASE M1 they would be very much appreciated. Ive spent a reasonable amount of time trawling through the existing posts on the forum, however would always appreciate additional advice!
To anyone who manages to read through all of that thank you so much!
Nathan
Build:
Case: NCASE M1
Monitor: Undecided
Nathan
