syndicated
- Mar 25, 2014
Hi guys (and gals!)
My first post here but I'm a longtime lurker. I recently got my hands on a Ncase M1 and I'm pretty excited to build a new machine to use for the next few years of school. Here is where I'm at so far.
PURCHASED
Case: Ncase M1 Black
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor
Motherboard: Asus Maximus VI Impact
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1866
Storage: Samsung 840 Pro Series 512GB 2.5" SSD
GPU: EVGA GeForce GTX 780 Ti Classified K|NGP|N Edition
I would like some advise from those familiar with this case some help with the following components. Specifically with space, noise and temp.
CPU Cooler: ???
Fans: ???
Power Supply: ???
The purpose of this build is to be a small non-mobile workhorse. I'm a 1st year engineering student here in Berkeley and aside from heavy gaming, the unit will also be used for big data and heavy computation. I would also like to poke around with overclocking the i7, and obviously also the KINGPIN GPU, so the PSU and cooling needs to be sufficient to *hopefully* be able to. I'd also like to keep it as silent as possible but not at the expense of above goals.
I appreciate everyone's help in advance! In terms of budget, I'm not too concerned with the cost at this point. I'm also pretty confident enough in my ability to be able to perform (or to learn) how to do some some light to medium technical modification to things like the case or the PSU if needed.
Looking forward to your thoughts!
PURCHASED
CPU Cooler: ???
Fans: ???
Power Supply: ???
