luckylinux
- Mar 19, 2012
I'm currently planning on upgrading my Home NAS / server on ZFS.
Current configuration:
- FreeBSD 9.1
- 1 x E5-2620 6C/12T CPU
- 64GB ECC registered RAM
- 2x2.0TB Mirror (ROOT) + 6x3.0TB RAIDZ-2 (DATA) -> 12TB usable space
I'm planning on leaving FreeBSD because I don't really feel at ease with managing it (I don't have enough experience probably). Furthermore it doesn't provide any virtualization solution (other than Virtualbox which is what I'm using). A possible solution would be to make an all-in-one ESXi host, leaving storage to openindiana/omnios + napp-it. Another one would be to use ZFSOnLinux and use a GNU/Linux distribution and virtualize using KVM.
Next configuration:
- Gentoo GNU/Linux + KVM virtualization
- 1 x E5-1650 (v1/v2 depending on availability)
- 64GB registered ECC RAM or 128GB
- 2x240GB SSD (ROOT) + 2 x (6x3.0TB RAIDZ-2) (DATA) -> 24TB usable space
For the SSD I settled and already bought 2x240GB Crucial M500 thanks to their integrated power outage protection.
The currently used HDDs are a mix of WD RED, WD Black and TOSHIBA DT01ACAxxx, hence all Desktop drives.
For the new NAS I'm not sure if I should go with entreprise drives (Such as WD SE or RE4, HGST/Hitachi Ultrastars, TOSHIBA entreprise) or stick with desktop drives.
From what I understood (and I'm not an expert in this field, so help me if you can
) entreprise drives have the following advantages over desktop drives:
- Longer warranty (5 years instead of 2/3 years in most cases)
- TLER/CCTL (Error Recovery Time limits)
- ECC memory buffer (Eccor Correcting Codes)
From these TLER/CCTL doesn't seem much of an issue to me since I'd be using software RAID (with ZFS). Longer warranty is interesting but I could get the same with WD Blacks for a lower price.
What really worries me is ECC: is it really so powerful / interesting or are we kind of talking about 1 bit flip in a day (same as ddr3 ECC)?
What really determines if entreprise drives are worth is how your data is worth. Well, while I admit I have some important data (personal photos, documents, ...), it's not some million dollars business or anything like that.
What would you therefore reccomend: entreprise or consumer drives
And would you agree in mixing different manufacturers / models in a vdev in order to lower the risk of simultaneous failures? I always heard it is bad idea to build huge pools of disks in RAID environments from the same batch of drives because if the batch was flawed many drives would fail before the array could be rebuilt
- FreeBSD 9.1
Next configuration:
