thenixhex311
- Apr 30, 2005
Ok. The anticipation has been killing me, and I was finally able to order the last 2 parts I needed for my computer (Leadtek 7800GTX and a Maxtor DiamondMax 10 16mb 200Gig SATA HD)
I didn't get the hard drive yet, so I couldnt start installing XP, etc. But I did hook up the computer, sans HD to my monitor to see what was going on in the bios of my new system. The specs are:
AMD 64 3700+ San Diego with Thermaltake XP-90 Heatsink (and 82mm Fan)
MSI K8N Neo 4 Platinum (non SLI) motherboard
1Gig Corsair VS
FSP 530W ATX 2.0 PSU
Leadtek 7800GTX
Creative Audigy 2 eX Platinum
and then it will have 2 Optical drives and 3 Hard Drives (2 SATA- 1 IDE)
There are 2 120mm thermaltake case fans one in the front of the lian li pc65b Plus case for intake, one on the top for exhaust. One 90mm fan in the back for exhaust and then the 82mm on the heatsink for cooling.
This will be my first AMD system. The rig I have now is a P4 2.8Ghz Prescott 1 Gig ram, etc. I don't really plan on overclocking TOO MUCH (as i have no clue what im really doing)
I did bookmark a couple sites with specs on safe/stable OC's for the 7800gtx, and the Neo4 mobo has a Dynamic Overclocking feature that ranks things as "Private, Seargeant, Corporal, General, Commander, etc.)
These say they increase the CPU frequency. Mine was by default set at Seargeant (increase CPU freq. by %3) There are 4 more 'upper' choices after that %5, %7, %9, %11
First question what would be my method of attack if i wanted to tinker around with the settings here? Try one, run Prime 95 for a while, if stable, go up?
I dont really think im going to OC the ram... its just VS and runs fine at 2.5-3-3-8, not sure how it would overclock anyways.
ANYWHO....the main reason I posted. I went into the SYSTEM Health area, and saw the CPU and System temps, fan rpm and stuff. Are these numbers right? wrong? acceptable?
System Temp 36c/96f
CPU Temp 43c/198f
Sys Fan RPM 1854rpm
CPU RPM 1795rpm
Northbridge RPM 7758rpm
CPU Vcore 1.37v
+3.3v 3.37v
+12.0V 11.67v
+5.0v 4.99v
I forgot to mention i used arctic silver 5 on the cpu and I have a zalman mcf fan controller controlling the 2 120mm fans, 1 system fan (r. exhaust) and the cpu fan
thanks for the help!
1Gig Corsair VS
Leadtek 7800GTX
System Temp 36c/96f
CPU Temp 43c/198f
Sys Fan RPM 1854rpm
CPU RPM 1795rpm
CPU Vcore 1.37v
+3.3v 3.37v
+12.0V 11.67v
+5.0v 4.99v
