At my office, we had a spaghetti of wires, so i ordered a patch panel and today I began wiring the office. The only problem i've had is 5 wires that were ran last year to the new server rack. These wires do not terminate at the location with a wall jack like the others. They are directly ran to the server. When i tried to install the wire in the patch panel, wired exactly like the others, i cannot get a connection. The tester indicates mis-wires and other errors. Do you have to wire the patch panel differently if it is not terminating at a wall jack?
Computer -> Wall Jack -> Patch Panel -> Switch = Works Perfectly
Computer -> Patch Panel -> Switch = No connectivity.
Thanks for any inputs.
