My overclock wont clock!
MechWarrior
Slob Ur Knob - $5
Ok guys.
The setup:
SN41G2
Barton 2500
2x256 Geil 3200
Whenever I bump the FSB from 166 to 200, the board WILL post properly and procede to load windows xp. However, sometimes it gets to the XP screen, othertimes it wont. Either way, it reboots and starts the cycle over. I first thought it was the ram, but the timings are the same as it is when its at 166 FSB.
I make sure the ram is running in sync mode aswell.
Any ideas? Questions? Stuff ive forgotten?
Could it be because I cant touch the voltage it wont work? Ive seen plenty of people hit 3200 speeds with their 2500 in the same SN41G2 though.
I dont have the option to change voltages. My temps are fine, its not heat at all.
I get the same thing although i have a different mobo and 2100 ram. When I buy my ocz 3700 ram, if you havnt found a solution ill tell you if its ram.
