I am strongly considering buying a rangemax 240 router from netgear, but it appears to be
the there is no rangemax 240 wireless adapter for a pci slot. I know it is possible to connect
a pcmcia card to a desktop, but is that a good idea? there is the
NETGEAR WPNT121 which is a little pricey, but doable. the desktop will be 2 floors away
from the router ( and I have trouble commiting furniture to a specific spot in the house),
being used as a file server via remote desktop, and have a laptop roaming
the house. What whould you do?
DraftN is not an option. N can be an option after the standard is set,.
