Take the x-qpack and all of its clones as a starting point.
Raise the motherboard tray up about 4 inches and mount it there on a shelf. Now just tuck the PSU and the drives underneath. When you put the system together, you'll be able to tuck all the wiring under there out of sight as well.
I'm all about windows (not Michael Microsoft's Windows) so there would be windows at three sides like the qpack clones, except they would half-height and shifted up on the side panels. With mesh in the lower half for ventilation. You could even put a window in the front panel with this design.
So you would basically be able to cleanly display your mobo, gpu, etc up top, display-case style. All the junk would be tucked below out of sight, out of mind. I don't why why they didn't make the case that way in the first place. It would look much better and be easier for the user to work with.
Let me know what you guys think.
