Carlosinfl
Loves the juice
- Sep 25, 2002
So I finally got Untangle configured at my small office. It's configured to be an actual Firewall w/ NAT and not the other option where it's a router:
DSL Router (Dynamic IP) ---> Untangle ---> Dell 2761 switch ---> LAN
It works great and I love the applications you can download & enable/disable on the virtual rack. There are however a few questions I have and I can't find the answer to.
1. Can I move the arrangement of applications on the virtual rack?
2. If I configured DynDNS on the Firewall and from anywhere on the Internet I can ping that hostname I created from DynDNS but how can I remotely access & make changes to Untangle? I would like to be able to modify the Firewall while I'm from home or another location.
3. I've downloaded 'OpenVPN' and configured the VPN server. I was told then I need to generate clients which I did. I created 3 user clients but my question is how do they VPN into the LAN? Is there a client they need or how does it work?
4. I've installed the Firewall application but it seems to block virtually nothing due to not having any rules database by default. Is there a rules template I can download that has a general policy that's safe for basic use? I can't even tell if it blocks DDoS and other commonly used cracker methods.
