My first overclock
blairellis
Only up 200mhz for now, don't want to go too much higher on the stock cooling. Once the Zalman goes in, I'll crank it up.
Judging from your screenshot you only run one instance of Prime95 which doesn't fully tax your CPU as you have a dual core system.
Check Prime95's documentation on how to run multiple instances. You also can run Orthos which will take care of making multiple threads/instances. I will put the link below.
http://sp2004.fre3.com/beta/beta2.htm
