Hello, thanks for looking.
The case that I will be using for this project is a Lian Li V800B. Here are some renders of what I want to do with the case. I just need opinions or if anyone sees anything that can be a problem or even thoughts.
1. Will be a LCD installed into 2 5.25" bays.
2. This will be the hardest thing involved in modding this case. I wana mod my Logitech Z-5500 control panel to be built into the right side of the case. I have not yet pulled the unit apart, I doubt it is gona fit or the arranged the way I have it in the render but there is hope. This is my biggest concern of the project. Also on the rear and the side of the unit there are inputs, this will serve as another problem. Here are links to what the unit looks like - front view here and the back view here
3. This will be a simple grille, on the other side will be mounted a Raptor X with the window visible through the grille. I will possibly add lighting to make it visible during the night.
4. This will be the radiator for the WC setup, not a lot of room inside so I will be mouting it to the outside of the case. I might run into problems running the tubing once PCI cards are in place.
5. Holes for hose pass through.
6. Plexi Window
Please help me out with anything you can, thanks for looking.
6. Plexi Window
