My AM2 Overclocking results
zoomtm
My results with my new rig:
Windows won't boot; but:
My PC:
Case: Antec Performance TX Server Case
PSU: Antec SmartPower 500Watt 2.0
Motherboard: ASUS M2N-E Socket AM2 NVIDIA nForce 570 Ultra MCP
CPU: AMD Athlon 64 3500+ Orleans Socket AM2 2.2GHz @ 2.7GHz
RAM: CORSAIR XMS2 1GB TWINX DDR2 800 PC2 6400 512x2 @ DDR2 900
Video Card: BFG 3D Fuzion 7600GT PCI-E 256MB 128-BIT @ 592/1720
Hard Drives: 2x HITACHI Deskstar 7K80 80GB SATA 3.0GB/sec in RAID 0
CD Drive: NEC DVDRW 16X Black IDE
Floppy Drive: NEC Floppy Drive
Cooling: Stock, 4 80MMs, 1 120MM, and 2 PSU Fans.
3DMARK 03: 14057
3DMARK 05: 6283
3DMARK 06: 3223
AQUAMARK 3: 83270
Processor = 3500+
Socket = AM2
core = Orleans
Stepping = 2
old MHz = 2.2ghz
new MHz= 2.7ghz
Orginal vcore = 1.25
New Vcore = 1.42
Cooling = stock
Temp (idle/full) = 24/34
Motherboard = asus m2n-e
Memory = corsair xms2 512*2 ddr2 pc6400
Vmem = 1.90
Stabillity OK?= yes
HTT = 245mhz
Chipset Volt = stock
Timings = 5-5-5-18-2T
(cf)Eclipse said:
can you do 1T command rate at those speeds?
Hm..I'll try tommorow...I'm also going to try 2.8Ghz tommorow...going to run a burn in program overnight with CPU at 2.7GHz.
Right now ASUS needs to get a new BIOS out fast, the newest one cant OC worth crap. I'm using the original one and it takes about 10 restarts before the board will boot up with overclocking...after it boots up its rock solid. Guess its the chance I take for buying a board thats a few weeks old.
Thx for the nice comments ;)
hmm:
good luck
btw, two things:
1. small pics
2. use macro. the image won't be so blurry ;)
managed to get my hands on an unreleased bios from asus for this board...didn't help with overclocking though :(, maybe the next public release will fix things up
if you want the unreleased BIOS you can private message me...
BIOS posted at 4.4GHz:
I found a way to get the ram higher than 1.95 Volts. ASUS includes an overclocking program which allows you to give up to 2.5Volts!! and 1.5625 Volts on the CPU. But if I raise the FSB, the PC just freezes, im going to try clockgen to see if it works with the ram voltage up higher. Also setting the CPU to 1.5625 volts only gives it 1.425 volts. So I'm sure ASUS will probaly fix this in the next BIOS release. Keep this in mind if you are going to buy this motherboard!
I got the CPU at 2.805GHz - didnt last long enough for screenshot (sorry for blurry pic...got excited and couldnt hold camera still lol):
2.797 seemed stable: and only 39c
Now im waiting for ASUS to send me a BIOS that can up the core on the CPU or a new version of the AIBooster program that will allow me to. I have a feeling this CPU has a lot more to give :).
I thought i was the only one having problems with this board. I'm experiencing the exact same thing, super stable when its running, but when i go to restart, it is a pain. also, after rebooting, sometimes the overclock doesn't stay.. meaning i have it at 2600 and reboot and it will show 2000 instead. but when i go to bios, it shows my HTT still at 260.
anyways, awesome clock, just wanted to know if you ran into any of my problems and if you ahd any solutions.
BIOS problems aside pretty nice. Have you considered upgrading the cooler? Seems 3Ghz might be yours with a better BIOS and cooler
I'm at 2.8GHz stable right now. Yea...I'll upgrade when I get some more money :).
