Multiplier probs
FrozenOver2
Alright I cannot change the multiplier of the system in sig. I used to be able to but i cant anymore it just doesnt recongnize it and keeps it the same. I wanna hit 2.4 again but right know i am stuck at 2.2 stock 3200 speeds. For some reason when ever I try to up the FSB anymore than that it starts having problems booting windows. IRQ isnt something something problems. I was wondering if I should just toss this chip and get a moble I am watercooled and it doesnt seem to have any advantage. Its pissin me off cause I used to be able to run 2.4..
IRQL_Not_Less_Or_Equal?
If that's the error you're getting, it's your RAM, not your CPU. Try setting a divider so your memory FSB is lower than your core FSB.
Thats the one thanks.
So if I wanna run DDR 400 divide that by 2 then its 200 so I would be fine right.
