Lets say if you can see more then 1 wireless connections on your wireless card at home. Is there anyway to connect to both of them to "shotgun" your bandwidth? So lkike it would double?
the only way that you could do it with 2 different AP's at once would be to install 2 cards and "bond" them together in linux using the bonding module, or in windows using a program similar to Nicexpress
